Crash in v. 3.1.5
I am running 3.1.5 on a laptop as a server and logged in with the WH3 console as a client. I have just recorded three channels with a different effect in each, Rand1, Rand2 and Rand3, respectively. I adjusted and recorded this effect and then copied it to 21 other channels (I'm making a fire effect) using "Chan 109-111+copy+Chan. 112>132". All seems great UNTIL I select Chan. 112 to check that the effect was copied correctly. I look at it and it seems fine and I press "Next" and the console crashes with this message:
Error: Assert: 'CurrentPel' is FALSE
File: misc/selectionmanager.cpp (Feb. 18 2010), Line 1147
Version: v3.1.5 (b 2725)
When I press "Abort" the entire console crashes. When I press "Ignore" at first it repeats the error message. The second time, it cleared the error and I was able to check out my channels by pressing next as one would expect.
Attached is the error window.
Dave
