HOG 3 DP8000 & HIPPO
Hi
Sorry to bother
Pls advise me on the following
I am trying to hook up
1 x HOG 3 Console
1 x DP8000
2 x Ethernet Switcher
4 x Hippo V3
Attach is the hookup
Pls advise me how do I set the Artnet in HOG 3
as the Hippo is having Artnet 0-1 (Which can be set on the MA Console )
Pls also advise me on the IP address
thanks
Parents
  • HI Chris,
    From what i remember the Hippo has two network ports, one Hippo Net and One Artnet.
    They need to be separately configured.
    I always go for ArtNet like 2.xxx.xxx.xxx SubNet 255.0.0.0
    So the drawing should have a second ethernet wire for HippoNet if you want to use the ZooKeeper.
    The Hog uses Broadcast as standard for ArtNet witch makes it very easy to get it to work.
    Let us know how it went.
    /A
Reply
  • HI Chris,
    /A
Children
No Data
