I just bought a tablet PC and want to turn it into a RFU for my IPC. All of my ip addresses seem to be correct. My router looks like it's sending and recieving. I turned off my firewall. I am running windows 7 64 bit. I also am rnning Hog PC as an administrator. Am I missing something?
Check your networking settings. You can view information on several links from this page: www.highend.com/support/training/wholehogtutorials.asp
You should be able to log into your show running on your Hog iPC. First launch the show on the Hog iPC, then try to connect to it from the Hog 3PC start menu.
Make sure you are running the same version of software in both the Ipc and your tablet pc. If you are not running the same version you will not be able to connect.
