I forget the syntax to clone fixtures on a HOG 3. I have swapped Showguns for VL3500 washes and wanted to "clone" the fixtures in the show I already programmed
If you have added fixtures to your show and want to copy existing fixture programming, you should use the Replicate Fixtures button on the toolbar in the Fixture window. If you have replaced fixtures in your show and just want to change the type of fixtures used for existing programming, use the Change Type button on the same toolbar.
