Hi there, I wanted to know if anyone help me I want to do a figure 8 moving pattern with my intelligents. Let me know if you guys know if you know how to instead of just a circle pattern with pan and tilt effect. appreciate it.
A moving head would do it if you leave it at the home position (straight down) and select Circle from the effects directory.
If the moving head needs to be tilted up to say the stage then you need to select the SINE effect for PAN to be twice as fast as the SINE effect for TILT. No offset.
Cool it worked, how do I flip that figure 8 pattern on its side instead of it being upright like this "8" its laying on its side like the infinity sign.
