Is there any way that functionality could be added so that you could go into the edit fixtures window (under patch) and click on a gobo slot for a fixture and click set, then be able to type any name you want in the box, on a fixture by fixture basis?
I put a lot of custom gobos in my fixtures, including even different gobos in fixtures of the same types.
It would be so helpful to be able to click set and name my own gobos that are actually installed in the lights under the slot names, so when I go to choose a gobo while programming, I actually know what they are.
This would be so helpful.
