dmx output window
It would be so helpful if you could click on a channel value in the dmx output window and be able to set it to any value you want.
It would be even better if you could also use the first encoder wheel to scroll through 0-255 on the selected cell.
This is priceless for troubleshooting.
Then there could be a clear button at the top of the dmx window to release what you have changed.
Is this possible?
