Need info on how to Upgrade the iPC front pannel
Okay probably a stupid question, but I just downloaded the latest 3.1.6 installed the files for Hog 3 PC, DP8K. I cannot figure out where to install the iPC Config panel.msi . I keeps saying "The HOG iPC configuration panel must be upgraded from within the HOG iPC Configuration panel"
Where is this located? When I look at the system info it says the "Hog iPC front Panel firmware version is 3, PLD version 0.
Do I need to update this?
