Offset effect when replicating fixtures
I often need to replicate fixture to put my show onto a larger rig than the one it was programmed on. I then need to go through every cue in the show to adjust the offset on all the effects for the new fixtures. Would it be possible to have an option when replicating to adjust all offsets by a certain amount of degrees? Maybe even be able to select a different amount for each parameter and/or fixture?
Any thoughts guys, is this a good idea or not?
Leggy
