(2773)Bug Report: Command Line shows wrong fixture selection on broken fixture range
Date: 6/11/11
Software Version and build number: 3.1.6 (2773)
Number of displays: 2
Connected USB Devices: 2 Touch Screens
Networked Devices: (6) DP-2000
Detailed description of the problem including instructions to reproduce (if possible) and exact syntax used:
I thought this was something that had been logged and repaired previously, but I guess not.
If you have a bunch of desk channels patched:
1-5
11-15
21-25
31-35
And you enter '1 THRU ENTER', you should (and do actually) select fixtures 1-5. This is shown correctly in the programmer.
However, the command line will show a properly formatted (blue) command indicating a selection of 1-35.
So, um, yeah.
PG
  • This is a known issue and discussed a few times before.
    But I guess it's not top priority (cause many people know how selection works and the feedback is wrong)
    Though, it would be nice to have it fixed someday...
