Bug Report: (2773) Clearing the command line
6/14/10
V3.1.6 b.2773
1 - Hog 3
1 - Mini Wing
1 - DP8K
1 - DP2K
ESP Vision
Issue - While merging Catalyst information into a show file, I keep running into instances where after I update a cue, I am unable to clear the command line. What happens is the keypad and clear button are locked out. Typing in a number, or hitting clear does nothing. However, I am able to select a group from the touch screen. Once I select a group, it unlocks the keypad and clear button and I am able to clear the programmer.
*EDIT*
This does not happen when pressing update. This happens when using (Record XX Enter Merge) syntax.
