(2773) Bug Report: Extreme Lag in Cue Playback
Date: 6/14/10
Software Version and build number: V3.1.6 (Build 2773)
Number of displays:
Connected USB Devices: (2) Touch Screens
Networked Devices: (2) Hog 3 / (6) DP2000
Detailed description of the problem including instructions to reproduce (if possible) and exact syntax used:
(I've e-mailed this show file to Brad.)
Cuelist 8 is the main show. As we play back cues, there is anywhere from a 1-2 second delay from when we hit GO to when a cue fires and then there is a very jerky start to the cue. This seems to be more pronounced the farther we are in to the cuelist. (You will see that we have updated the paths of most of these cues to 'Speed Up' to try to alleviate some of this. Please look at the same cues with default paths as well.)
The Hogs and DPs are set up on the same port with all different user numbers. All devices are on the same network. The show is patched with each universe cloned to its 'B' device. i.e. DP-A1 is cloned to DP-B1.
Please let me know what other information you need.
PG
Parents
  • [QUOTE=Cmy.dk;48199]So, soon there will be problems to alle the widget users. ????
    Widgets should not be affected because they don't actually do any processing....they just transmit DMX signals. The processing is transferred to the main CPU of the computer or console the widget is hooked up to.
    For example you can hook up widgets to the rear USB ports on DP-8000 to gain access to more of the 16 available universes via 5-pin connectors (as opposed to ArtNet for example).
Reply
Children
No Data
