Help with effects
Hey all,
I'm a new road hog user. I've been starting to get the hang of things but am still trying to wrap my head around the effects engine.
I have two identical moving head lights. If i run one to run in a circle counterclockwise and the other to run in a circle clockwise how do i get them to sync up their movements. I want them to be at 0 degrees at the same time, then one will be at 90 while the other is at 270, then they will both hit 180 at the same time, and so on. Basically I want the two lights to mirror eachother.
Does this make sense? I have set the cycles and effect size to the same setting but they never match.
Wolf
