Rem Dim ignores HTP Lists
Not sure if this has been asked before, but is it possible when you use the rem dim function for it to ignore levels that are set by HTP faders.
I frequently will put house or work lights in an HTP fader and don't want them to black out when using rem dim.
This is on a IPC running 3.1.6.
Eric
