Bump Levels
I recently had the privilege to do lights for a band with a completely conventional rig. I used a LP-2000, the first time I can remember using it. I have to admit, I kind of like that board a lot. Anyways, one of the things that the LP-2000 does that I had never thought of before was, it has a bump level master. I have been trying to think of how to do this in hog, but the only thing i can come up with is having different cues on a fader. If you want 50% bump go to the cue where int. is 50, 100% go to that cue. But the problem is, when I do my busking shows I put Positions in the cue stack and and use the fared for intensity.
Is there a way to easily manipulate the bump level?
