Road hog touch screen isues
Recently i have been having more issues with my road hog.
When starting up the right hand screen does the usual out of range scenario and whereas it would usually come up with the FPS logo it goes into some sort of test mode, displaying different coloured lines horizotally and vercitall in a test sequence.
I had the desk apart and checked all the cables on the sceen were seated properley and found the screen control cable ( from the controls on the top of the board ) had seperated from the touch screen, i reseated this and the sceen worked fine until i came to load the console on a different show. it happened again so i assumed the cable must have came loose again but it hadn't.
I have today had the console apart and made sure everything is connected correctly and it all seems fine, up to now the problem hasnt re ocurred.
Im about to re install the xp image and software to ensure its not a software problem, has anyone else had this problem or has anyone any ideas on it??
Regards
Mike
