3.1.6 (2773) - Palette Merge not functioning correctly
3.1.6 (build 2773)
2 x H3
2 x DP8k
2 x Monitors
(BEAM is set to SEPARATE PARAMETERS)
If I have a palette with multiple parameters in it (eg a Beam palette with ALL beam parameters in it)....
Then I select some fixtures (that are in the palette), just touch one beam parameter (eg zoom @ 0%) then MERGE it into the existing palette....
.. then it REPLACES the palette with a zoom only palette!
If I select a single fixture and try the same action (touch its zoom, then merge into the palette) then it strips all the other parameters for ALL fixtures in the palette... leaving only ZOOM.
This is a really major bug!
As I am used to Merging Zoom and Focus values into multiple palettes on a daily basis.... or CTO values into all my colour palettes based on camera balancing).
D
