Tap Tempo?
Hey gang. I wanted to know if there is a way to setup a tap tempo for manually strobing fixtures. I am at a show tonight where there are a ton of drum builds into a chorus. It would be great if I could tap strobe the lights to his tempo. Thanks!
Long Live :hogsign:!!!
  • The feature you want is called called "Tap Sync". See section 24.5.5 in the manual titled "Using a Cuelist as a Chase".
    From the manual:
    To adjust the rate of a chase using Tap Sync, hold down the Choose key of the master the chase is attached to, while pressing the master's Go key repeatedly to the required beat. Wholehog OS will learn the speed of the chase from you, in a minimum of two beats; after this, you can release the Choose key.
