Is there a way to record an effect and put it on to a handle, where the handle intensity changes the rate of the effect and not the intensity of the effect.
Currently the only method for adjusting effects with the fader is with IPCB faders and in that case we control effect size (not rate). You can however hold down the choose key for the master that your effect is on and adjust the "cuelist effect rate" on the second encoder wheel.
