Chromalech jarag 30 31 channel
if possible i am looking for a 31 channel of this fixture.
25 Dimmers plus 6 channels of macros i think.
Manual attached .
Regards Cormac
  • Hi Cormac,
    We actually can not create a library for this fixture because it is just 25 Dimmer channels. I just programmed a bunch of these as desk channels and it worked out really well as I was able to create many different effects and copy them etc.
    The current library system does not allow for multiple instances of the same parameter within a fixture. We would have to make a dim1, dim2, dim3, etc up to dim25 and then you could not use grouping, buddying, or copying. So I suggest that you just patch them each as 25 desk channels and go for it (I did not use the macros on my show).
