IPC DVD
Heu guys
Just looking for thoughts on a DVD burner in a Hog IPC, I have a few kicking around. Would it be able to utilize the DVD burn function? I ask because I have tons of Blank DVDs i'm trying to use before buy any CD's. It would be simply for archival purposes since I carry a USB stick for onsite back up.
Kurtis
  • Probably not going to work. You would need to be able to install the drivers for a DVD burner, and the XPe software is "locked down" with good reason.
    Why not just tranfer files off the USB onto a computer to burn to DVD if you are not using discs onsite then?
    Hope this helps. :)
  • It might work, it might not. It might be able to burn CDs, but not DVDs. You can try it, but you're on your own. Obviously it's not a configuration we're going to support.
    The IPC software is built around burning CDs. It will entirely depend on how compatible the DVD burner is with the commands used by a CD burner.
  • I'll see what happens. I'm just trying to avoid that step of transfering shows to USB, Guess i'm just trying to be lazy :D
    Kurtis
