reference pallettes
Scratching my head here.
Are reference palettes currently working in latest software?Hog PC
-Select some fixtures using the command line adjust pan and tilt record position palette 6.
-Select some fixtures using the command line,select position palette 6,adjust pan/tilt slightly,press record,select P mask,select more, "allow refs",record position palette 7.
Don't get a ref symbol in palette 7 so i guess it is not referencing palette 6.
Perhaps i need a refresheer course.
Thanks C
