Slight Problem with intensity when running efx engine
I've had this happen a few times to me and I've tried to figure out how to work around it but no luck so far.
I have a rig consisting of LED's, and Moving Lights.
I control the intensity of the units through separate cuelists that are associated with masters. (ex. list 1 has the led units at 100%, list 2 are the spot units at 100%, and list 3 are wash units at 100%. I then bring these to masters 2.3.4 to control them via the faders).
Let's say I have master 2 (the led's) at 50%.
When i run an intensity effect (as in a chase) the led's bump up to 100% while running the effect and bypass the set level on master 2.
I've tried to cancel the intensity bump by setting the priority level of the cut on master 2 to a higher level. It worked keeping the LED's at the 50% level, however the effect did not run with the list at a higher priority.
As a quick work around I've just lowered the grand master while running these effect but of course this also effect the spots and washes as well.
How can I have it where I can run an intensity effect on the led's while having the overall intensity of the unit still controlled by a separate cue list as opposed to bumping up to full?
Thanks.
Justin
