hog 3 spontainious re-start
another tale from the wierd side! running hog 3, have had 2 spontainious restarts in as many days. v3.1.6, playback wing, 1-20" elo external, ps keyboard, on same power source, what the, what the? had cue running, some values post cue update in programmer, no effects just static scene up, was not programing at the time. console was looked over, clean as new, although mother board battery may be low as console has not been "remembering" the correct time. clock does not reset on startup, but after each morning startup clock seems to go further and further out of time. power metered ok, no other known setup anomalies.
  • I would swap out as many of the power related accessories in your setup that you can such as multi-taps and power bricks and also try running without the PS keyboard for a day or two to see if the problem goes away.
  • [QUOTE=c_muenchow;49400]I would swap out as many of the power related accessories in your setup that you can such as multi-taps and power bricks and also try running without the PS keyboard for a day or two to see if the problem goes away.
    will try without keyboard. i forgot to mention that the hog and perifrials are on an APC ups. ups is in exellent order. each item (H3, ext touch mon, wing, router, dp) are all plugged direct into ups on the battery side. my other workstation items (laptop, and desk lite, set tv monitor) are on the surge protect only side.
