Group master bug
Mikey ray25/9
v 2826
roadhog FB with RH wing:
artnet visual mac
I have a show that one wing has group masters turned up to a show that only had one wing so i enabled the wing to be the one with the group masters then deleted them , I then turned it back to my other playback wing with cues on.
problem was when i selected fixtures that had group masters and hit Full i had no output , backed up the show then reloaded and all was fine
tried it twice to make sure and same results
mikey
Parents
  • Got the show file. Don't know what's going on with our upload server theses days. It seems to be lying to people about the file size and stuff but I did get the show file.
    I think the chaos you are experiencing is probably stemming from the fact that the group exists on both the template and page 1 so I think when you delete the group off the template it is reverting to the stored fader level as set by master 10, playback bar 2 on page 1.
Reply
Children
No Data
