Select Odd, Even buggy
I've meant to post this for way too long now (over a year easily).
Grab a handful of fixtures, like (8) MAC 700.
Put them in a position, grab a gobo, start roating the gobo...
I'll do a Select Odd so I can do the "-" key and have the odd ones rotate the other way.
Then if I press Select Even it doesn't select them correctly.
It selects random fixtures, some even, some odd. :(
Last night we played with this for several minutes and it is all over the place. Certainly not reliable. :mad:
It really doesn't matter what sequence of programming you are doing.
It always seems to select incorrectly.
Could some others give this a try and see what results you get? :06:
