When starting up the Hog3PC application: is there a way to automatic switch on the MAP key, so that i can use the keyboard right away? now i always forget to switch from abc to MAP...
There is currently not a method to do this, however with our upcoming v3.2 release we will have keystroke macros. With this you could record a macro to toggle the MAP function and then trigger this with the startup comment macro.
