Hi
Did anyone got this working ?
PC running Win 7 , HOGPC 3.1.5 , WYG R22
Not able to get them connected
Did the following and do it for both WYSIWYG and Hog3PC...
Right click on the desktop icon, click properties, and under the compatibility tab check the option "Run this Program as an Administrator". This should clear the error up and allow you to connect.
Both HOG PC and Wysiwyg need to run as Windows XP Service Pack 2 Compatible. There may be various combinations that will work but as I have Windows 7 64-Bit installed. To do this right click the shortcut either from the windows menu or desktop shortcut and select properties. Select Compatibility Tab. Check "Run this program in compatibility mode for:" then select Windows XP (Service Pack 2)
Still not working
Pls advise
thanks
