Fitting a solid state drive?
Hi, wondered if anyone could shed some light on this.
I want to fit a solid state drive to my Roadhog. I am aware of the possible speed issues but want to fit one as my desk got dropped yesterday and the hard drive is not well and want to prevent issues should something like this happen again.
Now, the Roadhog drive is IDE and all the SSD I have seen are SATA.
Will A SATA drive connect to the Roadhog motherboard and be recognized and install the operating system ok?
Any info greatly appreciated!
S
Parents
  • [QUOTE=skier;51251]Had a go at installing a Solid State Drive and get the following error when installing the image of memory stick. It gets to the point of asking if you want to do a clean install or preserve show files. Obviously there are no show files to preserve so selecting clean install.
    The Script has received the error CODE 5
    from command : cmd/c diskpart/s THPart2.txt
    Does this mean anything to anyone??
    Something like this? (see image in attachment)
    So what's eventually the best solution to resolve this problem when re-installing Road Hog software to a new hard drive when using the system restore bootable USB key?
Reply
Children
No Data
