Can HOG3PC connect to ESP Vision (2.3) on the same computer? The Vision manual talks about connecting HOG2PC to Vision but in the HOG3 section talksa about requiring an ethernet connection.
Yes, you can have ESP and Hog3PC on the same computer. Make sure you have at least one valid Ethernet connection active (doesn't have to be plugged in, just active) and the two programs will communicate with each other over that. Also make sure to have the Visualizer Connectivity drivers installed.
