I have been trying to record a cue list for each of our gobos but when you assert the list it brings all the 250's to straight down and then asserts the gobo'. Any suggestions on how to change the gobo with a list and not affect the movements.
It sounds like you touched position when recording your cues. Open the cues and knockout the position values so that position is only in your position cue.
To open a cue: List 'x' cue 'x' open Select the units Hold the backspace key and hit the position button (this will knockout the pos. values for that cue) Update or close the window
