This bug does not affect functionality, but causes me to scratch my head when I go back to examine or edit a palette...
When I record a referenced position palette into a per type palette, the position information does not display in the new palette's editor window.  However, the reference position information still recalls correctly in the programmer.
select a fixture, [Position] 1
[Record] [Position] 2 {Per Type} {Allow Refs} [Enter]
[Position] 2 [Open]
Position information is blank in the edit window.
Adding other ICB palettes in the same sequence, the other palette references do appear, but position does not.
Changing {Per Type} to {Global}, all palette types (IPCB) are missing.
The behavior is consistent if I record to Color or Beam palettes.
Show file is available upon request.
Date: Dec. 1, 2010
Software Version and build number: 3.1.7 b2826
Hog 3PC
Number of displays: 2
Operating System: Windows 7
Computer Specs: Intel Core 2 Duo 2.26GHz
Other running applications: Chrome
Connected USB Devices: 1 (mouse)
Networked Devices: none
List any errors reported by the software: none
