Wondering if anyone else has noticed or come up with a solution to an issue I consistently get with my Color Blazes (patched as generic RGB). Basically, if I try to strobe them using a sped up step effect they seem to sine the base value of the intensity. In other words while strobing they seem to cycle between 0% > full intensity and 50% (ish) > full intensity so I can never get a consistent on/off strobe effect. Am I making sense?
What settings are you using in the FX? i.e. - Intensity @ 50%, STEP table, Size @ 50%, etc...
You might try playing with the Size and Length settings. If you want the look to have "more black" or be "more off" then try decreasing the size and increasing the length. If youwant the look to have "less black" or be "more on" then try simply decreasing the length.
