'Matrix' Editor for DMX Outputs
I would like to see an option panel in the future that allows easy flexible mapping of universes to the outputs of widgets and DPs. While it is fairly simple to clone universes, this can get a bit unwieldy, especially if you are using every available universe on a DP. (That requires adding an additional 'phantom' DP to clone a universe to while moving others around.)
I have heard this requests from several crew chiefs and techs.
This could be a matrix editor or something similar to the way Art-Net is mapped.
I think it would also be advantageous to allow mapping of one universe to multiple physical or Art-Net outputs as opposed to having to clone universes. As edits are made to a patch, it seems silly to have to make a patch edit in multiple locations when you just want identical data coming out of multiple ports.
Thoughts?
Phil
