Ok, so when I updated our iPC and (3PC) to v.3.1.8 the strangest thing is happening. I can only open shows off of backups now. It gives me the fps::exception error which when detailed says: desktop callstack process, and the thread is a different number every time. I've since talked to High End and they advised me to wipe the console and re-update, which I have with the same result. I'm wondering if it is a problem with the show. The odd thing is every show I create will open and work perfectly off of the backup file, but will not open off of the regular show file.
At a loss,
-Nic
Any advice would be greatly appreciated!!
