Road Hog + Wing
I am currently touring a show on a Road Hog Full Boar and a Road Hog Wing. My backup console is an IPC. I use the IPC for checking the rig, etc. as well as backup. If I boot up the IPC with the current show, it thinks that the wing is attached, even if I turn it off in the control panel. The wing is loaded with HTP cues with conventional fixtures.
The IPC without the wing attached outputs levels for all the conventional fixtures on the wing as if it were attached and all the masters at full.
Shouldn't it disregard the wing completely if not attached?
