Recording Cues with time
A couple of questions, I feel like I've used the syntax "Record Cue xx Time xx Enter" before, but it doesn't seem to work in 3.1.8. The cue records but uses the default timing.
Also, when merging values into a cue that doesn't have values for the fixtures previous to the merge, the new fixtures use the default timing instead of the assigned cue timing, is there a workaround for this so that merged values will keep the assigned cue timing?
Running 3.1.8 on an IPC.
Eric
Parents Reply Children
No Data
