FLASH + go on flash function?
I have a small question concerning FLASH and +go on flash.
I have a simple list with two cues. Cue 1 with ch# @ 100%, cue 2 with ch# @ 0%
I want to use the flash buttons for GO so I put the "+Go on flash" on.
Then I need to limit the list with fader to the needed level. This level is different during show but fade on/off is allways the same (just to explaing why level is limited with fader and not in the cue levels :) ).
Here´s the problem:
The intensity bumbs to 100% (over the fader set level) when going to Q2 from Q1 (this is with flash level set to 100% and fader @ approx 70%).
If flash level is set to 0% from master options the list bumbs to 0% with flash+go.
The best way I found around is the problem is to set the flash level around the level mostly needed. But this is no good because I need to modify the intensity fader levels during show so I end up with different fader level than set flash level most propably.
Because of this I would like to have "+go on flash" function also on flash-none selection.
Or even better, a GO in the flash drop down menu.
Any ideas?
