Ideas for effectsengine
I think that the effects engine would be absolutely great if you added a few features to it.
* A spread parameter. Yes, like fanning offset, but an additional parameter for it.
* A "plus" parameter (No it's not a good name for it, but that's what it's called in chamsys). Simply determines which side of the base value the effect is working. One normal option where it works as normal, plus where it only works above the base value, and minus where it only works below the base value.
* I think 100% size should be what's now 50% size. (Because when it's at 50% size, it is going between 0 and 100%, an amplitude of 100%).
* To get the effects visualised on it's table, and being able to select which tables/parameters to visualise.
* An integrated curve/table editor, this is where my big ideas are.
- Being able to copy an existing curve and work with it.
- Editing and creating the tables points, and select if the points should be of type corner or beizer curve.
- Creating table points of kind "Palette point", where the points value is referenced to a palettes parameter. This could be used to create the "Effects between palettes" as someone on the forum requested.
- Working with multiple curves at the same time, like working with layers in photoshop.
It could be looking something like this
forums.highend.com/data:image/png;base64,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
  • Thank you Gildebrand,
    Many of these items are already on our to-do list for an effects engine rework we have planned. I will see that those that are not already logged get logged.
    thank you,
  • * A spread parameter. Yes, like fanning offset, but an additional parameter for it.
    The current way is good quite good and simple for me, though you have to do a bit math or add an additional fixture... But a fast way to spread offset with current syntax would not be bad. Like Steph's suggestion 0 thru enter in other thread.
    But controlling effect spreading would be nice...
    See this thread forums.highend.com/showthread.php?t=3596
    * A "plus" parameter (No it's not a good name for it, but that's what it's called in chamsys). Simply determines which side of the base value the effect is working. One normal option where it works as normal, plus where it only works above the base value, and minus where it only works below the base value.
    A way to have only the negative part of table would not be bad.
    See this thread forums.highend.com/showthread.php?t=3573
    * I think 100% size should be what's now 50% size. (Because when it's at 50% size, it is going between 0 and 100%, an amplitude of 100%).
    Well, that depends on what table, what base value you are using and on what parameter.
    Like Sine wave on intensity with base of 0% and size 50% results 0%>50%, cause negatives values are cut out (there is no negative intensity)
    and btw, there is no size 100% on pan and tilt... Hog uses real values.
    Sine wave on intensity with base of 50% and size 50% results 0>100% (Sine goes between -50 and 50)
    Mark on wave on intensity with size of 50% and base of 50% results 50%>100% cause mark on has only positive values.
  • Another idea is to add Part and Buddie parameters to the fx-engine. To create a part/buddie effect now, i'd have to select part/buddie-type and then enter the offset again.
  • Hello,
    Just read above that you are planning a rework of the Effects Engine.
    Please please please don't change it too much. In my opinion, the dreadful way in which the MA deals with effects is it's major let down so I very much hope your changes will not spoil what is already fantastic.
    I would love to see a feature however whereby a cue stack can be turned into an effect.
    For example, plot 2 cues with a CMY fixture changing between any two colour palettes. Then, turn that into an effect, which can then be assigned to other CMY fixtures, where fanning and size/rate adjustment is possible.
    I believe this would add a huge benefit and give more control over the effects, without making it over complicated and time consuming.
    I'd be grateful to hear your view on this.
    Cheers
    Colin
  • I agree with Colin (above). While it is possible (with an amount of maths and some mucking around) getting a specific order to your chase is hard and impractical on the fly.
    Being able to save chase cue stacks as single cues would be very valuable.
    However, using macros there is a way to do this Colin.
    you can select 'assert list X' in the macro box in your cuelist window, and of course 'release list X'.
  • Hi Henry,
    I think you have misinterpreted my suggestion. I am already aware of the use of macros to control other cuelists, but thankyou for the thought.
    To elaborate on my suggestion, I would love to be able to plot a series of cues in a cue list and then tell the console that I want that cuelist to become an effect (not a chase - but effect just like sin, step etc). Then, whatever those cues did, I could apply them to other fixture of the same type, or a range of fixtures then have full control of offset, rate, size etc, just as if it were a sin wave.
    This is possible on the Magic Q and is an absolutely fantastic and powerful feature that opens the door for some really easy to create effects. Hopefully Flying Pig will consider implementing it into the improved effects engine.
    I'd love to hear their thoughts.
