Hello,
I have come across a couple of problems when it come to the Roadhog and an external ELO touchscreen. Before 3.2 and after.
1st.
Why must we always go in to control panel and selected the external screen and calibrate it on start up every time?
I'm I missing something?
This is possible on an XP PC machine with and an ELO monitor. Setup once and all set. Same with Point Of Sales machines using ELO touch screen and embedded XP.
2nd.
With that problem, when I create an opening look on boot up via a key stroke macro the calibration is offset due to the IOGear USB to VGA adapter and external monitor attached but not yet selected and calibrated.
I can only auto lamp on my fixtures but not run several cue lists.
I tried a key stroke macro to set up the screen but it needs to run the calibration tool.
Any idea?
Apart from that, we love 3.2
One bug so far but we have addressed it and was told it will be in the next update.
Thank you for your time,
Dave
