Wonky Wing Weirdness??
I had some weirdness with hog3pc v3.2 just now.
The 10-key buttons would enter double-digits with a single button press. For example, I would press "1", but "11" would show up.
Also, the setup button would not get me to the Control Pnl/ Preferences/ Network/ Shows/ Patch buttons. It would pop up the Desklight Level and LED brightness options.
I uninstalled v3.2 and reinstalled v3.19. The wing works as it should in v3.19, so I don't think it's the wing.
Is this just a v3.2 bug? Or is my wing being wonky?
  • Usually when the keys are doing double presses, it's a value in the preferences under "Key Timings." I know I've had to turn down the key timings a couple of times in the past, but I don't remember what the setting is off hand.
    But with the setup button, did it work on the front panel on Hog3PC but not the wing? If so, it sounds like it might have been a corrupted driver installation when it installed 3.2.0.
    I'd give it a fresh download and reinstall and check.
    J
