Hi all! Got a quick couple of questions that i believe i know the answer to but want to have clarified.
First does the hog iPC (3.1.7) have the capability to output art net?
If that is a yes then will this pre vis setup work.
Hog iPC on 3.1.7 running to a hub that connects to the pc running esp vision and to a G5 running Catalyst 4x. Then the taking the output out of the catalyst into a input card on pre vis pc.
So does this work? Is there a easier way?
:1zhelp::1zhelp::1zhelp::1zhelp:
