Bug #15370: X-wing backlight gets confused on first backlight timeout
3.2.1
Hog3
DP8000
X-Wing
Playback Wing
Just had this same issue with my Hog3/X-Wing.
Console timed out...all backlights turned off. Hit Pig on the console and it came back to life, but the X-Wing did not. I had to go into Pig+Enable to get the backlights back on.
  • Appears you are right Jon and I think there was a mis-verification of a defect on our part as this bug goes away if you manually set the backlight... and the bug will return if you power cycle the Xwing and don't manually reset the backlight. We're reopening the bug and taking another look. Thanks for the report.
