From what i know, from image 1.8.1 the XPE version is 1.8.0 but the software version is then 3.2.1. If you use the 1.8.0 download, software version 3.2.0 is applied.
Hope this helps....
Fons
[QUOTE=WHoog;56726]I just downloaded the latest Roadhog 1.8.1 image but when i installed this the roadhog is telling me that i installed the 1.8.0 version.
That is actually incorrect. If you use XPE Restore v1.8.1 then the console should report itself as running XPE v1.8.1.
It looks like the wrong final image was posted to the web for Road Hog. I have corrected this and now the download should now be reporting 1.8.1 after install.
Skier, you should be fine with 1.8.0. Nothing really changed from 1.8.0 to 1.8.1 except for the included build. If you downloaded the v1.8.1 XPE image before I fixed the "reported XPE version number" about 4 days ago then you can reinstall the latest 1.8.1 XPE download for RoadHog but it is really not necessary.
