I bought a broken Road Hog. While buying it all seamed with no fault beside the missing graphic card. Based on the valid Road Hog I already have, bought a new graphic card Asus EN6200LE TC256/TD/64M5/A from German HES distributor.
However, when installed that new graphic card, only got the image on one monitor attached to the graphic card. The other one which is attached to the motherboard gets no image. Only then I noticed it is a different version of Road Hog, and my valid one is using the Asus P5B motherboard, and the one I bought uses Advantech AIMB-562.
I don't think the problem is with the motherboard since VGA on it works, but the problem would be that on this Road Hog version with the AIMB-562 motherboard there is no driver for VGA in HES XPe image.
Does anybody know which graphic card is used on the Road Hog with Advantech AIMB-562 mother board?
Regards Tenty
