effect-off pallet
On a Roadhog V3.2.1
Not all fixtures are responding to a effect-off pallet:
creating:
group 1 - effect engine - setting Pan Tilt to off (all fixtures stop) - record effect 101 - enter
playing back:
group 1 - play back effect 1 (al fixtures running circle effect)
group 1 - play back effect 101
then al fixtures stops the effect except the first fixture! that one is still doing the circel.
even when creating an off-effect for just the first fixture does not work.
I did a new show with other fixture types with the same result.
is there some wrong the way i make the off-pallet?
Parents
  • It's kind of a bug mixed in with a feature. The system should understand that per fixture is implied with the record task but instead it tries to use "per type" instead and when it does that it flubs the first fixture as the "type rule" and then adds the rest of the fixtures as the "per fixture" rules.
Reply
Children
No Data
