RoadHog Midi problem 3.2.1
My Roadhog is not even recognizing that the M-Audio Midisport Uno that I have plugged into it even exists with software version 3.2.1. To make sure that it was a software problem, I downgraded to 3.2.0 and it worked immediately. I am going to stay with 3.2.0 for now, is there anything else I can do to make it work in 3.2.1?
  • So in version 3.2.1 the M-Audio device does not show up in the drop down menu of the midi in or out settings of the midi tab in the control panel?
  • Correct, I restarted the console with it unplugged and plugged in, and even tried different ports, but it never showed up in the midi inputs or outputs list in the control panel. I have time today that I do not need the midi, so I will try to update to 3.2.1 again from 3.2.0 to see if for some reason it just needed to be reinstalled.
  • Sometimes launcher won't refresh the drop down menu right away when a new device is plugged in.
    Try this:
    Boot up the console to start screens
    Plug in the Midi 1x1 (the USB light should pulse slowly on the device)
    It may not show up in the drop down menu yet
    Launch into a show, it should be there now
  • Garrett
    Did you get up and running?
