Hog PC, Midi Uno
I've got a PC running HOG 3PC 3.2.1
Windows sees our Midi Uno, and it shows up in the Midi configuration in the Hog software.
However the 'console' wont respond to MIDI triggers, though our iPC and another Road Hog do.
The Uno appears to be working fine, as it's indicators fire when we send cues.
Is there some setting I am missing on the Computer side to make HOG respond?
  • Check one thing.
    Press Setup
    Then on your Primary Screen, press Network.
    On your Seconday Screen, the Network Screen should come up. Press the Console Number of your HogPC (Most likely #1 if you have no other consoles on the network) and press Settings at the bottom of that window.
    Check to see if you have the MSC Enable Checked or the MIDI Notes In checked if you are using MIDI notes.
    That's about all I could think would be the issues. I've used the Uno in a few installations and not had any issues.
    Hope this helps. Take care!
