(3.2.1) Bug Report: IPCB fader at 0%, GO starts cue and outputs at 100%
I have a cuelist with the master set to IPCB. I would like to be able to trigger this cuelist from a (comment)macro, but only want to see the output when the fader is set to 100%. When the fader is set to 0%, and I press "Go" (manually or via macro), the output of the cuelist is set to 100% and the cue starts. This seems to be strange behaviour to me. When moving the fader up, and back to 0% disables the output of the cuelist again (like it should). Until the next GO, then the same thing happens again.
This behaviour was also present in previous releases - nothing new in 3.2.1 ;) .
