When i create an effect i like to initiate it in a small size so 'the roof' doesnt go ballistic and the LD starts to shout 'NO NO NO thats not what i want!'.
My way to start a small fx is to sellect fixtures, hit effect, and then for example select the the size box of the pan parameter, hit SET, type 5, enter.
In previous software versions a sinus path would be selected with a subtile movement of 5 degrees.
Unfortunately after i hit enter my size jumps to 800!! repeating the above sequence for the 2end time gives the correct value to the size but then the LD is already asking what I'm doing....
The incorrect value in the size box also appears on other parameters then pan....
My current system includes:
HOG 3
Hog PC (networked notebook)
1x DP8000
No external screens
Grtz,
Pepijn
